I am looking for a few more fuse terminals as in the picture below.
My fusebox is from a MK3 Escort (I think), but I have a feeling that sierras and other early fords use the same terminals.
Can anyone tell me if I can buy these somewhere, or does someone have a fusebox with these in as part of their donor loom that they no longer
require?
Any help is much appreciated.
Lars
PS: While I figure out how to add the pictures to the thread, they are also in my archive
[Edited on 23/6/08 by Lars]
Image deleted by owner
[img][/img]
I'm pretty sure you'll be able to get them from any decent electrical supplier.
try premier wiring as they sent me a load when I ordered my relay holders. (probably a different size though.
There's also a special tool to use rather than soldering the wires in.
I did have a look on their website, but could not see any. I will send them an email though to check.
So far I have not tried to solder them in (well only the one, unsuccessfully as the wire was dirty) instead i cut the wires that were already attached
and solder these.
