Until I can get my V6 box machined to size, does anyone have a Type 9 gearbox for sale to keep me ticked over.
Cheers Dan.
I have another v6 box here in the Midlands (long input shaft though)
Dan
As well as the old box you donated to me thats in many parts in two boxes..... i have one complete type 9 sitting here doing nout
If it will get you sorted your welcome to use it.
Thanks fella, but i need something that can go straight in so i can start mapping the MS.
Cheers Dan.
Read my post again dan, the 2nd box is complete
I would have read your post my good friend, but i was typing at the time
I may take you up on that one cheers fella. Will drop you a line to sort something out, would probably be more interested in the complete box
ATB Dan.
Not sure if you still want a type9 for 4cyl motor but I have one for £30 in Bath if you do. Regards, Martin
Machined to size?
Won't a 1" spacer plate do
Dan the box is from a late sierra 1800 which i presume true as it has the lecy speedo sender and wire as you can see in the pic, i lifted the lid and
its as clean as clean can be. Externally its as it was when taken from the sierra, there is also a home made short shift which just needs some longer
M8 bolts.
No need for cash just give it a go and if all is well we can sort something out i'm sure.
