Does anyone have, or know a place that has mushroom inserts for sierra uprights for sale?
Also, does anyone have the drum brakes for an english axle for sale?
Cheers, Chris
£10 for 2 the mushrooms send me a u2u with your address forget the postage. Their the MK ones, unused.
Mushroom inserts from Rally Design I think
MNR?
Re brakes unless you plan to Autotest the car go for discs it is now the cheaper option.
Escort Mk3 240mm dia solid front discs (also used on early Sierras) -- dirt cheap
https://sslrelay.com/buypartsby.co.uk/brake-pads-newer.php?recordID=4673
I have link on another PC for brackets to take Sierra rear calipers.
[Edited on 30/7/08 by britishtrident]
short track 123 on here sells brackets to convert to disc. The disc centre will not fit over the half shaft hub without a bit of a tweak, the disc
centre is a bit too small so grind the outside off the rear hub. Some
here on ebay.
[Edited on 30/7/08 by Peteff]
