http://www.locostbuilders.co.uk/viewthread.php?tid=9668
Anybody whose broken a non EFI Pinto got a spare drive 'pin/rod' and mechanism to drive the mechanical fuel pump from the cam on the timing
shaft to the pump?
I'm converting my EFI 2.0 to run off carbs and want to use a mechanical pump. I've got the pump but not the drive pin for it!
I'm not sure if it needs to be a 2.0 tho.
Thanks,
James
See reply in E&T
I've u2u'd you!
James
You have reply
