anyone know where i might get one like this? kind find anything similar for decent money. SBD seemed to want like 50 squid...
[Edited on 24/9/08 by blakep82]
Two rod ends. A piece of Hex bar. A friend with a lathe.
Looks pretty simple. Not sure the alternator is very well supported in that install though?
[Edited on 25/9/08 by SeaBass]
i used a small s/s rigging screw about 5mm, cut the ends off and weld on a bit of s/s tube to the end on the alt and i cant rember what i put on the
other end but it works beacause of the left and right hand thread and it has locking nuts fitted to stop it coming loose, cost was bout £10
http://www.bainbridgemarine.co.uk/content/default.asp?PageId=367&CategoryId=104&ProductId=451
something like this
tommy
Does it need to be that posh?
The standard adjuster from vauxhall is £17!
good luck
tommy
Originally posted by blakep82
loggyboy, it doesn't have to be that posh (nice if it is though) the standard adjuster for my engine is on the power steering pump, which i ditched.
I know this thread is ancient but I make this sort of thing
http://pages.ebay.com/link/?nav=item.view&alt=web&id=281563215865
I don't have any listed at the moment but will again in a day or two if any one is interested!
Specials not a problem either
Phil
