anyone got a drill bit i can borrow,needs to be between 15 and 19mm with a shank of 13mm to fit my pillar drill...cheers peeps
I've got one John but you're a long way away from me!
If you cant get one I'll send it to you, or they sell em in machine mart, ask for Blacksmiths' drills.
Chris
I've a set too, but much the same location as chrisg......
Try Axminster
http://www.axminster.co.uk/product-Armeg-Blacksmiths-Drills--Large-Drills-with-Reduced-Shanks-21885.htm
£5 to drill 2 holes,i,d rather eat my ferret than do that (in best yorkshire accent)
hopefully someone nearer will have one ,if not cheers peeps
Originally posted by theconrodkid
£5 to drill 2 holes,i,d rather eat my ferret than do that (in best yorkshire accent).
hopefully someone nearer will have one ,if not cheers peeps![]()
Got a round file haven't you Conrod?
17mm holesaw??? will fit a drill chuck.
the metal is 3 mm thick and life is so short so a drill is really the only way
Blimey. I thought I was tight!!!!
i have one.But postage is about 3quid each way you do the sums
the metal is 3 mm thick and life is so short so a drill is really the only way![]()
where are you ?
A hole saw will easily cut through 3mm steel - I do it all the time at work Just go half way through from each side - or drill a small (3mm ?) hole at one edge of the `circle` - thats what I do when cutting holes in 12mm ally
i,m in london,ive devised a cunning plan to circumvent the need for said drill,thanks anyhow peeps
