my daily (2.0 Zetec Focus) has killed the thermostat housing. i think its fairly common on these at the moment, a couple of friends with them have had
the same issue.
anyway, anyone got one??
Mark
I don't have one but mine went and turned out to be a ford only part (£50 trade) where the rubber seal is onto the head was cracked and a chunk
missing out of the housing!! 1.8, 2000 reg mine is.
John
hi, yes exactly the same issue here.
ok, ford it is then!
thank you.
Mark
I have two spare sitting in the shed. All in one piece including the stats inside. £10 incl postage. Could get it in the post in the morning if you want one.
edit to say sent you an email
sounds good!
can you confirm it is like this :
[Edited on 8/10/08 by Meeerrrk]
Folks,
there are differences between the silvertop and blacktop thermostat housings. Specifically around thread sizes for the sensors.
In a kit application this may not matter. However in a tin top, you need to make sure it's the right housing for your car.
Focus engine will be blacktop....
This any good
thermo house link
thanks for the info, and thanks for the link.
ordered one this evening, be here on saturday.
Cheers guys,
Mark
