This is such a silly question but i can't think of the answer.
Imagine you've got a washer, cut a quarter away and weld on little tabs on the inside.
What is it called?
Its used, in conjunction with a locating groove to hold rods in place. I know scewfix do a pack of them (heck, halfords probably do them) but i
can't think what they're called to go and buy them.
(i need two to hold my new seirra hand brake cable in place at the drum end).
Circlip?
[Edited on 12/10/08 by dogwood]
http://www.circlipindia.com/e-type-circlip.html
http://www.circlipindia.com/c-ring.html
[Edited on 12/10/08 by CRAIGR]
E clips?
[Edited on 12/10/08 by omega 24 v6]
good god - 10 mins and nearly 30 views and one answer.
Nope, its not a circlip, they've got the little holes that you use the circlip pliers on to open them up.
These don't have the holes, you use the screw driver to prise them back out of the groove in the peice being held and then they fly over the
garage. The three tabs on the inside of the 'washer' are at the back and the two open edges (from the cut out bit).
11 minutes and the right answer - thank you. This site is great.
Right, just need to source some now
Ctype or e type as in my previous post Mike
Yeah i know, i started to write my reply before you're post had come up initially. We're just too quick at solving problems on here
Now, how do i get someone to clean and tidy my house so i can spend more time in the garage / out (without having to marry them / pay them?)
Go to Thailand and get a takeaway
I removed one from my idle adjust earlier. They are called "the little b*starding thing that nearly took my eye out before disappearing off into a dark corner of the garage never to be seen again!!"
ah, right, well i need two so can i have that one and another (probably in the same place you find the first)
Heads up
Eclips
