Hello all,
I have never painted anything as large as my chassis before and worried that if I attempt to paint it with a compressor and spray gun, i'm going
to F**K it up.
Does anyone know of any good cheap bodyshops around Lincolnshire area.
Does anyone have any painting tips or quotes that people have given them to paint there cars?
Any input would really help me.
Cheers James
[Edited on 09/12/2007 by jnormandale]
Can't help with the question I'm afraid, but you might get a better answer in the Bodywork forum than 'For Sale'
Have you thought about powder coating?
Possibly cheaper than getting it professionally spray painted and providing it's done properly it should be more durable too.
I would expect to pay between £2-300 to have it blasted and coated.
Sure I willget shot down but here goes... what is wrong with brush painting enamel paint??
Advantages are that it is very withstanding and can be touched up easily.
I think a chassis is a great idea to teach yourself to spray given that once its finished, most of it will be hidden anyway!! I havent done any
spraying in a long time myself but will be doing some shortly to relearn (on someone else's nosecone!! I'm not daft ya know!! Hi Ben
). You may even find a local college course if you are lucky.
Have you tried the library for books on the subject?? I'm sure i have also seen cheap dvd's on ebay - dont know if anyone has tried
these??
Preparation is the biggest thing anyway. Contaminants can be a killer (dust, silicone polishes, grease etc etc) so you need a clean area to spray in
and take care with preparation before even thinking of applying any paint.
I'd say give it a go. Practice on scrap stuff before doing anything important and i'm sure you'll get there.
if you try to spray a chassis, most of the paint will miss and end up on the wall,get a small roller and a paint brush,red lead and gloss on top.job done
Painting a chassis isnt a great project for a spraygun unless your using a small touch up gun it wastes more paint than owt else.Why not just get a
few large aerosols from anywhere but Halfrauds.
As Paul said give it a go who's going to see it.
Conrods idea is good gloss is a lot more durable.
Bob
[Edited on 11/9/08 by splitrivet]
Originally posted by JamJahAdvantages are that it is very withstanding and can be touched up easily.
yep - most of the paint will lost;
a small roller is the way - folks have painted land rovers and the result is pretty good.
Having both brush painted AND sprayed my chassis, I can tell you that the spraying was much faster and more enjoyable of the two. Yes, there will be
some paint wastage but it's an perhaps extra £10 on paint versus hours of brushing!
See this thread for my experiences.
Thread moved to correct section....
Fozzie
Apologies for refering to my chassis? I really meant body work, i.e. external panels, scuttle, bonnet and nose cone? Any tips?
P.S. sorry for putting it in the for sale section! Lol!
Lincolnshire is a fair-ish area do you want to narrow it down a little ?
I reber JeffC posted an excellent thread on painting a Westfield on WSCC. That is well worth searching for. He is a painter by trade but he goes into
a lot of detail about the prep stages. Ive never painted a car myself but have had a mate do one for me. I recall that it was the prep that was most
time consuming. You might save yourself some cash if you can do those bits yourself. Only downer is that the bodyshop will have an out if the end
result isnt quite what you want, however it shouldnt be too hard on a car with minimal bodywork.
Even if you do the stripping down, masking and rebuilding yourself you should save a good few hours.
Hi James
I notice that you are building a Haynes car.
If you are building it all yourself, then I reckon painting it should be a breeze for you if you take your time.
I am building a locost & sprayed the car in my single garage, with cheap m/c Mart kit.
I'm pleased with the results, esp. considering I've never sprayed anything before.
But bear in mind if spraying at home you will (should), be using non 2 pack paint, which means that the finish won't be as durable as a profess.
sprayed 2 pack.
My reasoning is the car is mostly garaged anyway, so this is'nt necessarily a problem.
Look up some old posts from Mark Allinson. He gave me some good pointers from this forum.
