Brake light switch thread?
fege - 11/5/13 at 09:07 PM
As the topic suggests, does anyone know what size thread the hydraulic brake light switch that's suppied has?
loggyboy - 11/5/13 at 10:10 PM
If its the same as most, its an imperial 3/8ths.
[Edited on 11-5-13 by loggyboy]
davidimurray - 11/5/13 at 10:19 PM
If it is metric will most likely be m10x1 tapered thread
fege - 12/5/13 at 07:57 AM
Thanks mates! I think my current switch is causing the spongy brake pedal and needs repacement. Or perhaps I should use an electical micro switch instead? Not sure yet..
davidimurray - 12/5/13 at 12:41 PM
Is your switched mounted with the outlet at the bottom? If so it is possible to get air trapped. Try removing the switch and fitting a bleed nipple instead and bleed to see if you he a solid pedal. I added an extra tee on mine to get the switch on its side, with a bleed nipple on top.
fege - 12/5/13 at 06:07 PM
Yes, mine's mounted just like that. Thats the reason that I suspect the switch i causing my problems. I'll fit a bleed nipple and se what happens and take it from there. Thanks again!
