Im still undecided as to what fuel delivery system to use.
A rough idea of cost of megasquirt would also be helpful.
Engine is 3.6 AJ6
Vote NOW!
Megasquirt.
Will probably cost around £400 inc throttle bodies etc to fit. As long as you can make your own manifold of course.
Either that or it has to be triple webers
I have a bank of three carbotooters off an outboard engine. They're big!! Probably big enough to tandem two pots per carb or get another set of matching carbs. No-one has cottened on to these carbs yet so grab them before they do!!!
Two lots of triumph trident TB's or cut some scabby carbs up and mount the butterfiles on the original manifold and use standard injectors. MS away you go.
3.6 guzzler will need this
Well, thats already pretty conclusive. Thanks guys.
