Hazard wiring query
CraigJ - 30/11/15 at 07:04 PM
Can anyone make sense of where these wires need to go?
I have a pre-made loom and i have 7 wires in the hazard wiring circuit.
The first 3 I presume are for the indicator switch as there are no other wires present for the indicators.
green/white, o/s indicator
green/red, n/s indicator
green/brown, flasher power feed, flasher relay pin 49a
then I have 4 left
green/pink, hazard feed flasher relay pin 49
purple, perm live
green, switch live
black, earth
What would be the best way to wire this up?
The hazard switch I have has 5 terminals. 2 are for the led and the other 3 work like this. Switch in off position, 1 & 3 continuity nothing to 2. switch on and continuity from 1 to 2 and none to 3 if that makes sense.
Will this switch work or am I better of buying a different one?
gremlin1234 - 30/11/15 at 07:47 PM
I don't think that switch (alone) has enough terminals.
however, the wiring colours you have are the good old BS wiring colours, so look at original mini, triumph, land rover etc for a switch.
CraigJ - 30/11/15 at 07:51 PM
After looking at wiring diagrams I have binned the switch and just ordered a savage switch with 6 terminals.
hopefully this will make it easier to wire up.
