Hi,
I am looking to buy a new performance exhaust for my Locost 7. the engine is a Burton tuned 1300 Crossflow.
Does it need to have a heat shield for the SVA test?
Does anybody have experience/ advice on the best system?
I was looking at the CCR Chromerzone system from Europa, cost is approximately £250-£300,
I would like to do Hillclimbs, sprints and track days, the car is booked for SVA test on the 8th sept so it needs to comply.
Thanks David
hi I have a 4into2into1 from a westfield I think its stainless as magnets don't stick it fouls the diagonal on my STMS and aries take it over the top rail so I have decided to make my own If you live within easy traveling distance you are welcome to try it for fit. Regards Arthur
Thanks Arthur
I have a 4-2-1 manifold it's the silencer that I am looking for,
Thanks David
Where are you?
Leeds, Monk Fryston
It doesn't need a heat shield. If you are going for IVA soon I would fit a nice quiet standard silencer to the car then look at a performance exhaust after you've passed.
Yes I thought about doing that, my present exhaust has a small split in the silencer and the tail pipe is does not have a radius
on the end, I thought that I might be able to have that welded, together with the correct radius on the end of the pipe. Is it
not possible to purchase a performance system that would improve performance and still conform to the IVA standards?
Thanks David
Originally posted by Lightybob
Is it not possible to purchase a performance system that would improve performance and still conform to the IVA standards?
Thanks David
Thanks David
