I've never fiddled with a diesel lump before, but I decided to replace the leaky rocker cover gasket on my LR TD4 engine myself... and what a
bloody faff it is! Seems that EVERYTHING is attached to the rocker!
Anyway, I decided that I may as well remove the EGR and change the PCV at the same time and boy am I glad I did! Both were absolutely clogged with
black goo! Amazes me that it was still able to breathe!
So I've been cleaning all the sh*te off various pipes and ports and my hands are black (yes, should have worn gloves!). Thing is, my mitts are
now red raw with swarfega and nail-brush actions and I've hardly scratched the oil-slick that's covering them!
What the hell makes a diesel so bloomin manky!?
It is a mixture of the soot and oil from the breather mixing which makes a nice black mess.
Removing the egr will help alot as this is putting c**p back into the engine.
Matty
Now the egr is off do the decent thing and blank it off, your engine will thank you and you will enjoy the drive so much more
I hate working on diesels - it's the smell of the diesel - it just clings to you and its not a pleasant smell like petrol
I've replaced the EGR with a 'blank'.
I think the missus will be making me wear gloves in the house when she comes home! I'm filthy!
I know what you mean I had to drill my dpf filter and I looked like a chimney sweep when I'd done. Lol
That's what you get for running on oil!
I'm tempted to try cleaning if not removing the EGR from our Alhambra TDI just to see what difference it makes. That temptation always seems to
wain the closer I actually get to the bonnet of the car though
Got fed up with the EGR playing up on my Kangoo so eventually just disconnected the thing, this sorted all the running issues.
Trouble was the engine management light was then permanently on - soon to be an MOT issue I think, if not already.
Have now reconnected it but have spaced the solenoid part away from the valve itself - this fools the ecu but doesn't actually operate the valve,
so (at the moment) all is working well.....
You may want to pull the intake manifold and de-coke it. The soot builds up and will eventually strangle the engine to the point it can't
breath.
I have a 2000 VW I just bought and it still has factory EGR @ 250k miles. I can see enough through the EGR port to know that that is reason it smells
like raw fuel when idling.
And don't forget diesel migrates through the skin into your blood stream and NEVER breaks down.. enough of this = death...
Originally posted by The Shootist
You may want to pull the intake manifold and de-coke it. The soot builds up and will eventually strangle the engine to the point it can't breath.
