Not having a good week with the MK. Went for a drive on Friday went to stop at a junction and the clutch went straight to the floor! The cable
snapped where it went into the factory soldered union/barrel, luckily was about 1/2 mile from my old mans house, so nearly killed myself pushing it
there! And managed to solder another union on, and all seemed good. In fact it seemed much better than before, I think it must have been binding on
something.
Then decide to drive the 7 to work yesterday, get onto a busy roundabout about 2 miles from work, and what happens, the clutch goes to the floor.
Being that I was in 1st I thought I would try getting going off the starter motor, and was amazed at how easily I got going and did the last 2 miles
in 1st gear! Had a look and the other bloody end had snapped!! Managed to get home by starter motor and 2nd gear and learned how to do clutch less
shifts which are actually amazingly easy in a BEC.
Just went out to fix the cable again and noticed a puddle of oil, trying to workout where it had come from, and noticed the bloody oil filler cap had
decided it didn't want to live in its plug anymore!!
So what else is going to go wrong, after I get a new oil cap and clutch cable?
Dont try and second guess a car and its faults, it will always be something you didnt plan for.
I carry with me a bag of choice spares and tools. Due to me investing in this tool kit and spares my car has not gone wrong once!!
Originally posted by -matt
.... Being that I was in 1st I thought I would try getting going off the starter motor, and was amazed at how easily I got going and did the last 2 miles in 1st gear! Had a look and the other bloody end had snapped!! Managed to get home by starter motor and 2nd gear and learned how to do clutch less shifts which are actually amazingly easy in a BEC.
in the olden days, when cars (and bikes) were less reliable people used to do clutchless changes all the time, just takes some practrice to match engine - gearbox speed - even easier on bikes, in fact, don't racers do that all the time?
When I had motorbikes I rarely used the clutch on the move, just for starting off. Clutchless changes so easy, it's hardly worth the effort of
pulling in the clutch
Simon
Yea I agree now, I knew people do the up shifts clutch less, it was the downshifts I was worried about. But gave it a bit of gas, gentle pressure on the lever and went straight into gear.
I do clutchless changes every day in my Toyota Aygo, it's not just a BEC activity. Up shifts are an absolute doddle and downshifts are pretty
easy too. I even do it in stop-start traffic queues. When I was about 20 I had a clutch cable failure in rush hour in Glasgow and managed to drive 10
miles through the city to buy a new cable, fit it and drive home. Just used 1st gear and starter when starting from stopped and did clutchless changes
once running. No big deal.
Part of my reason is the Aygo's weak clutch so I'm trying to minimise wear. It also saves a bit of left leg work!
I don't think soldering a clutch cable is good
A proper crimped joint or on a handbrake cable I drilled a bolt threaded the cable through the hole I drilled smacked it twice with a blunt chisel
then mig welded back the tail.
I agree that there is no need to be pessimistic with assumption more issues will follow, if you did two miles in 1st, you where probably running at
high revs, which alone may have loosened the filler cap.
Never driven a BEC, but particularly on the upshift clutch less is common on bikes.
And even with a working clutch I used to start the 306 in gear on a cold day as standard due to a shot idle control valve, as you say, its more or
less a non-event. With the three 306 is was a case of foot in, ignition, hope you could get out of the end of the road without stopping. Come the next
junction it was getting warm enough to consider idling.....
Daniel
It is a kitcar all part of ownership charater building and all that.
To be fair if it's snapped twice I would want to find out why, do you have a stop on the clutch peddle at the end of it's travel?
If not this maybe your problem (you can put a lot of force on the cable with your foot.).
Dan
If you can make it fit a BEC Capri clutch cables are strong, cheap and come with adjusters.
Stu
To be fair if it's snapped twice I would want to find out why, do you have a stop on the clutch pedal at the end of it's travel?
>>> The cable snapped where it went into the factory soldered union/barrel,
soldering will turn the cable to a solid rod that is more liable to snapping if it is being bent - can you not use a crimp on cable end? or buy cable that has one alread fitted on and thread it through the outer?
Hi.
Most of the MK Indy R pedal boxes have this common problem. Which gets worse as you depress the clutch pedal. This factory built race car was doing a
clutch cable every 50 miles. Typical MK quality engineering .
Cheers Matt
[img]http://
[/img]
i drove mine 11 miles home the other day with the throttle cable coming from under the bonnet over the dash and me trying to pull the inner part!!
Still managed a couple of over takes
Amazing how many traffic cops appear when this sort of thing happens
Originally posted by procomp
Hi.
Most of the MK Indy R pedal boxes have this common problem. Which gets worse as you depress the clutch pedal. This factory built race car was doing a clutch cable every 50 miles. Typical MK quality engineering.
Cheers Matt
[img]http://
Description [/img]
The one in the pic has just been put together wrong. Not great if it was built by MK.
Mine follows the same route but the inner cable doesn't touch the tube and has no signs of wear after 7 years.
Stu
Sounds like to me like the pedal needs a stop to prevent the cable getting pulled hard against its' limit at the clutch end.
Thanks guys, yes I do have a clutch stop, so there is only about an inch of pedal movement.
It's setup as per matts pic, not sure how could have the outer through the hole aswell as surely it would need to press against something?
I think the problem with the second break was the engine heat must have softened the solder and the cable pulled straight through the solder.
A new cable arrived today so will try and do something a bit stronger with this one.
At least these are little external issues - my Indy R had an embarrassing amount of similar issues straight out of the factory, from misaligned chassis, uncalibrated fuel guage, to a poorly setup pedal-box, two years later I was still substituting parts which should have been part of the original specification. Because of this i really wish id just built it myself properly rather than lazily ordering a factory built car. It is getting there now though, and is a so much better car to drive than the one that left the factory, and this is what makes the work worthwhile.
