I am replacing the cams on my Zetec and so need the cam cover gasket and cam oil seals.
Anyone know where I can buy these individually rather than having to buy the full head set.
Ian
Try Burton Power for Ford parts...
http://www.burtonpower.com/
ive had good service from gaskets for classics. Worth a try. Not sure how recent they supply for though. Seem to think they do quite a bit of recent stuff now.
Try Gaskets Direct. Don't know if they do Zetec, but prices are good and very quick on
delivery.
Good for gasket material in various thicknesses as well if you want/need to make your own.
Ford stealers. They should have then on the shelf for not alot.
I got one through my local motor factors - then found the other one by me had them on the shelf...they're needed to do a cam belt change (to lock
the cams), so should be readily available.
Just don't bother with Halfrauds...
