cad drawing of zetec and crossflow inlet manifold
MikeR - 8/11/10 at 05:07 PM
Hi,
Does anyone have a CAD drawing of a zetec and (or) crossflow inlet manifold?
I'm after getting some cut so i can make some inlets and need the cad drawing to get some prices.
ahunt - 8/11/10 at 05:14 PM
http://www.turbosport.co.uk/showthread.php?125526-ive-knocked-up-an-Eng-Drawing-of-the-inlet-flange&p=1536164&viewfull=1
Any help? Have to become a member though i think
MikeR - 8/11/10 at 08:33 PM
A little - although they only provide the PDF's now so i'd still have to get someone to convert them into CAD drawings for a laser / water cutter.
and unfortunately not crossflow
rusty nuts - 9/11/10 at 07:32 PM
Don't know if it will help but I used an inlet manifold gasket to get the shape for my home made manifold plate for my Xflow
NS Dev - 10/11/10 at 01:16 PM
surely you can use autocad Mike?
can give you a quick lesson if needed! an inlet, if you have a dimensioned pdf to work from, is not tricky.
To do them in CRMS plate, 8mm thick, will be pretty cheap at NSI, just up the road from you.
They are lasering me a load of bits at the moment. Their big flatbed laser gives a decent finish on 12mm steel, and still acceptable on 15mm.
