Is anyone out there still running their Duratec on bike throttle bodies or have you replaced with off the shelf units from Jenvey SBD etc?
Planning on fitting a Duratec next Winter so i'm in planning mode.
Thanks in advance.
Ours is a 2.3 on ZX9R carbs. I've done plenty of Duratec inlet manifolds for people running GSXR1000/1300 TB's also.
mines using GXSR750 ITB'S on a Fastdan manifold
thats GSXR, pics in my archive
[Edited on 18/3/13 by big-vee-twin]
Running my duratec on gsxr1000 TB's on Fastdans manifold too
No problems with the setup at all.
I would mention though that when you do come to buying the TBs make sure they come with a TPS as they can be a bugger to find and arent cheap.
Thanks for the info
Fastdan what Ecu do you use With the ZX9R Carbs?
And what ecus do you use with the bike throttle bodies?
Originally posted by Hillclimber
Thanks for the info
Thanks FASTdan would you ever change to TB's or do you think there is not much to gain and you are happy with the performance?
I was planning on doing it this year - purely because the GSXR1300 kit is what I would consider my 'flagship' kit and therefore I should be
running/endorsing it myself! The ZX9's drive amazingly with excellent low down torque, but 'may' be holding it back at the top end
(being a 2.3).
However I have recently aquired a set of 48mm bike carbs. Therefore these are next on the agenda as its a straight forward swap, sticks with the bike
carb philosophy but might just open up that top end a bit. Not only that but these carbs are truely a site to behold (think ZX9's on steroids!!)
so will be a nice talking point.
I will of course eventually go to the GSXR1300's, but these 48's are a nice easy stepping stone.
Originally posted by FASTdan
I was planning on doing it this year - purely because the GSXR1300 kit is what I would consider my 'flagship' kit and therefore I should be running/endorsing it myself! The ZX9's drive amazingly with excellent low down torque, but 'may' be holding it back at the top end (being a 2.3).
However I have recently aquired a set of 48mm bike carbs. Therefore these are next on the agenda as its a straight forward swap, sticks with the bike carb philosophy but might just open up that top end a bit. Not only that but these carbs are truely a site to behold (think ZX9's on steroids!!) so will be a nice talking point.
I will of course eventually go to the GSXR1300's, but these 48's are a nice easy stepping stone.![]()
Is there only one member running a Duratec on Bike carbs? Anyone else have an opinion?
Thanks to all who have responded so far...it has been really helpful.
Too late now, but anyone after a TPS I may be able to help - many of the later GSXR TB's I have in stock come with the secondary butterfly arrangement which includes another TPS. This secondary arrangement is removed in my TB kits so I often have them spare.
