Author: Subject: WANTED - 1600 Xflow Sump
nib1980
posted on 11/4/09 at 04:02 PM Reply With Quote
Hi All
Alfter grounding out AGAIN, only 12 miles after getting back on the road, I'm in need of a 1600 xflow sump
Ideally a big wing, or modified for improved ground clearance, or better still full dry sump setup!
BUT if nothing else a sump is needed.
Any one with anything let me know
Beer tokens waiting
Many thanks
posted on 11/4/09 at 04:09 PM Reply With Quote
Modify/repair the one you have?
nib1980
posted on 11/4/09 at 04:32 PM Reply With Quote
can't my welder has gone up the creek, and i'm sick of spending hours fixing the car, the engine has been our more than in, and i just want to bolt it together to fix it
Anyone?
clairetoo
posted on 11/4/09 at 05:31 PM Reply With Quote
Is it a shortened sump you have holed ? If not , why not cut it down , and cure your ground clearance problem ?
Crossflow sumps are not the easiest of steels to weld - I've done a few - but not a major job
Its cuz I is blond , innit
Claire xx
Will weld for food......
nib1980
posted on 11/4/09 at 05:38 PM Reply With Quote
true, and i tried but thanks to my welding crapping itself, i blew a hole in it, i guess i can clean it up but i'm not happy about welding it up myslef.......
David Jenkins
posted on 11/4/09 at 05:40 PM Reply With Quote
A bit of info on shortening a sump can be found here.
Just a description of the way I did it - might give you a few ideas if your sump is still standard.
U2U if you want any further details.
nib1980
posted on 11/4/09 at 06:55 PM Reply With Quote
exactly what i wanted to do, but like i said my welding is dire. youdon't fancy doing it for me? Naturally i can pay. or anyone else for the matter. I can precut my sump.
Many thanks either way
