karlak
| posted on 23/10/10 at 12:48 PM |
Lambda "bung"/bolt
I am after a bolt to block the lambda sensor hole in an exhaust. I have checked with the digital calipers and it looks like it is an 18mm Thread.
Anyone got one lying around ??
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
britishtrident
| posted on 23/10/10 at 12:51 PM |
The quick get the job done fix is screw in a Pinto spark plug.
[/I]
MikeR
| posted on 23/10/10 at 01:06 PM |
any car engine spark plug will do. They have them on ebay, i'm tempted with the one that has an internal hex (allan key) so that its IVA ok
instead of the standard bolt based ones.
RazMan
| posted on 23/10/10 at 02:28 PM |
I've got a steel one complete with weld in boss if that's any good for you?
Raz
Kev99
| posted on 23/10/10 at 02:48 PM |
UNIVERSAL LAMBDA SENSOR BOSS NUT M18 on eBay (end time 12-Nov-10 13:37:44 GMT)
omega 24 v6
| posted on 23/10/10 at 03:16 PM |
I made my own
Old sparkplug cut it down and weld in a button headed bolt I had cost nowt and looks good.
SPYDER
| posted on 23/10/10 at 03:46 PM |
Are you sure about that???
britishtrident
| posted on 23/10/10 at 05:01 PM |
Not any plug it has to be an 18mm plug and the only 18mm plug you are lilely to find easily is from a Pinto.
indykid
| posted on 23/10/10 at 05:38 PM |
if it's m18x1.5, you could also use a transit drag link......if you were really stuck
most spark plugs are 14mm, not 18, but as has been said, pinto plugs will do it
watsonpj
| posted on 23/10/10 at 07:08 PM |
My local exhaust placed had them. Didn't even charge me for it. :-)
MikeR
| posted on 24/10/10 at 11:31 AM |
eek, i thought most car plugs where 18mm. You live and learn.
