Author: Subject: Brake Bleed Kit
SeanStone
posted on 10/1/11 at 09:25 PM Reply With Quote
Brake Bleed Kit
Does anyone have an unwanted brake bleeding kit? Will be needing one shortly for the rover.
Failing that, are there any reccomendations on which to buy?
Will be doing it myself and for the first time so any words of wisdom are kindly welcomed!
big_wasa
posted on 10/1/11 at 09:47 PM Reply With Quote
Is that your post on the zs forum ? dont call it a rover on there Lol.
SeanStone
posted on 10/1/11 at 09:49 PM Reply With Quote
Lol nope I haven't posted over there, don't think I'm a member. I have a 220SDI that has almost cost me more than it's worth! The economy makes me smile though . And the adjustable wastegate
big_wasa
posted on 10/1/11 at 09:53 PM Reply With Quote
Oh my bad,
Clear bit of tube thats a tight fit over the bleed niple, jam jar and spare pair of legs.
posted on 10/1/11 at 09:59 PM Reply With Quote
get an eazibleed kit. I was in the same boat as you, having never done it before, and it was plain sailing all the way. Needed to be, because i was moving house and the kit was off to the new one under its own steam!
mookaloid
posted on 10/1/11 at 10:00 PM Reply With Quote
Another vote for eezibleed great bit of kit
SeanStone
posted on 10/1/11 at 10:53 PM Reply With Quote
Thanks guys
RazMan
posted on 10/1/11 at 11:02 PM Reply With Quote
Personally I don't use the eezibleed kit after having nightmares with one, giving up and coaxing SWMBO out into the cold from her 'come dancing in the jungle with a chef's brother' program - there's nothing quite like a good foot on the pedal while you nip round with a jam jar
Raz
dan8400
posted on 11/1/11 at 08:11 AM Reply With Quote
+1 for eezibleed also.
Best solution for when you're on your own
Dan
Hey - That's Journey!!!
dan8400
posted on 11/1/11 at 08:12 AM Reply With Quote
I will add one thing..... I had a Rover 820 vitesse. No good on that. There was no correct adapter for the reservoir.
Ford fitment for the Tiger was no problem and a joy to use
Dan
big_l
posted on 11/1/11 at 08:27 AM Reply With Quote
Eezibleed all the way !!
Check out my blog mnrvortxhayabusa@blogspot.com
Stott
posted on 11/1/11 at 09:21 AM Reply With Quote
Eezibleed is good but no substitute for a spare pair of legs. You need to keep an eye on it or it will Eezily explode fluid all over your car, mine is about 10 year old though
posted on 11/1/11 at 10:34 AM Reply With Quote
My bleed tube is a bit of rubber with a split in the side and a ball bearing in the end, about £1.99 from car spares shop. I put the end in an old shampoo bottle to catch the fluid and hang it on somewhere with a bit of wire then just keep an eye on the fluid level. It helps if someone presses the pedal for you while you watch for bubbles but it's not essential. We had problems with Easibleed on an Astra even following all the instructions to the letter reducing air supply pressure and everything but the good old bleed tube worked straight away.
Stott
posted on 11/1/11 at 05:11 PM Reply With Quote
I use a screenwash bottle of about 1998 vintage,
I think the M/Cs just like being pumped manually, Truth be told it's always easier doing it the old fashioned way, I did the kit car pedal with my hand and put the bottle where it was visible on each corner cos it's up on stands with no seats in it.
