Author: Subject: Turn indicator cancelling cam thing
Macbeast
posted on 3/5/11 at 06:55 AM Reply With Quote
Came to reassemble the steering column and the black plastic indicator cancel bit is missing
Don't suppose anybody's got one spare ?
Edit to add - Sierra column
[Edited on 3/5/11 by Macbeast]
David Jenkins
posted on 3/5/11 at 06:58 AM Reply With Quote
Got mine from the local Ford dealer's spares department - cost me around 50p.
Macbeast
posted on 3/5/11 at 04:47 PM Reply With Quote
They say that part's no longer on the system
Macbeast
posted on 6/5/11 at 10:16 AM Reply With Quote
Still need this and IVA's on 17th. Even a loan would be better than nothing.
Pleeeeeeeeeeeeeese ??
blakep82
posted on 6/5/11 at 10:23 AM Reply With Quote
annoying i know, but not a requirement for IVA (unless its essential to the indicators, like they won't work at all unless its there), sooo.... i shouldn't worry about it too much.
eg, its quite acceptable to have an on-off-on toggle switch, which is what i've got, and quite a few have a rocker switch
[Edited on 6/5/11 by blakep82]
________________________
Macbeast
posted on 6/5/11 at 05:52 PM Reply With Quote
Ah OK Blake. Thanks very much.
I'll forget it for now then. Went out today for a tour of the scrapyards but the've all gone !! :-( T hey're all trendy winebars now :-)
Macbeast
posted on 9/5/11 at 04:08 PM Reply With Quote
Blast !!!
The indicator cancelling cam thing is also the retainer for the upper bearing and thrust washer.
So I do need one after all
blakep82
posted on 9/5/11 at 04:17 PM Reply With Quote
could a steel replacement be made form some steel tube and a few bits of specially shaped steel pieces?
Macbeast
posted on 9/5/11 at 05:33 PM Reply With Quote
I think that's the answer. Just a sort of collar, without worrying about the self-cancelling lobe.
blakep82
posted on 9/5/11 at 05:42 PM Reply With Quote
i know the real ones are plastic, but i'm sure a steel pipe, or plastic pipe if you can get some easier
if steel, i'm sure you could weld tabs on for cancelling if you wanted to, if you can weld
