jlayton
| posted on 2/7/11 at 01:26 PM |
bush's for rear uprights wanted
as above need some bush's for both sides of the rear uprights. as my wheel is moving top to bottom and i can see the play in the
bush's.
cheers
Chippy
| posted on 2/7/11 at 02:19 PM |
What car, and exactly which uprights would be a great help. Ray
[Edited on 2-7-11 by Chippy]
jlayton
| posted on 2/7/11 at 03:14 PM |
locost, running drums on the rear. just took the top wishbone off and found that the problem is the 't' piece camber adjuster the tube
section of it is the rong size for the bush's. so i think the guy who built it as used the rong size tube for the bush's
jlayton
| posted on 2/7/11 at 03:35 PM |
can anyone tell me what size tube you use for the bush's ??
| posted on 2/7/11 at 03:54 PM |
A bit more information may help. A "book" locost normally uses a live axle , it sound like yours may be IRS? If so what make might help?
failing that invest in a pair of verniers and start measuring? Rally Design amognst others stock bushes
jlayton
| posted on 2/7/11 at 04:00 PM |
as far as im aware its just a locost gsxr1000 with irs, the bush's are the same as the wishbone 1's. so just need to know the tube size
for the bush to sit in .. 30/33mm something like that, just want to double check
[Edited on 2/7/11 by jlayton]
MikeR
| posted on 2/7/11 at 09:07 PM |
Unfortunately your answer is like saying "i've a problem with my car, what size wheels does it have?", when we ask some questions
your reply is "its a standard car with 4 wheels, an engine and gearbox - what size are the wheels".
Now I appreciate my answer doesn't help so .....
'Locost' IRS rear ends have been built by MK, MAC1, stuart taylor (plus some others but they're designs are more distinctive and
less locost looking). The offical locost book has a ford escort rear end with other versions being a modification of this hence the initial word
locost was in quotes. So the bloke who built the car was either building a manufacturers kit or its a home build / designed not standard locost. If
its a manufacture then we need to identify them and then someone with the same car will help. If its not a manufacters car then you'll need to
get some vernier calipers to measure it.
The simpliest way forward is to post a number of pictures of your car. We'll need some from the front, side, rear and where the rear section
joins to the bit by the roll bar to help identify it. Then we'll need some pictures of the part we're talking about as its attached to the
car. By doing this we'll probably be able to identify the car and then hopefully help narrow down the part (if its made by a manufacturer). If
not - we're back to you getting some vernier calipers and measuring it yourself.
Sorry if this isn't the reply you wanted, i'm trying to be helpful - honest.
