Author: Subject: MX5 front droplink mount bracket/1 poly bush for it
thefreak
posted on 1/8/11 at 11:09 AM Reply With Quote
I'm after the bracket which is welded to the front wishbone, where the droplink bolts to.
I've found a pic of the rear one which shows you what I mean.
It's the part that the bolt goes through at the bottom. Anyone know somewhere that sells just the bracket, as I dont want to have to remove the complete arm to swap it when I can just weld a new bracket back on.
Also, need 1 poly bush too for that droplink
liam.mccaffrey
posted on 1/8/11 at 11:21 AM Reply With Quote
what happened to the old one? Corroded, bent?
I very much doubt that you will find anyone who will stock a part that it welded to a stock wishbone.
I'd be inclined to just swap the wishbone or fab a new bracket yourself and weld it on. I'm not really sure which is more trouble, but I'd probably just change the bone.
I could have given you one before I junked everything
Build Blog
Build Photo Album
thefreak
posted on 1/8/11 at 11:25 AM Reply With Quote
Snapped I guess due to corrosion.
I've got a second MX5 that I'm breaking, but didn't want to start removing wishbones as it makes it a little more difficult to move around Plus it would also mean getting the alignment done on it again.
Think I might go down the DIY route. Time to get the jigsaw out
