steve8274
| posted on 17/10/11 at 08:06 PM |
wtd: sierra hazard indicator stalk
hi all
has anyone got a spare indicator stalk from a sierra they no longer require.
mine is from a j plate 1992 but seems to have developed a fault
thanks
steve
samjc
| posted on 17/10/11 at 09:00 PM |
Got some volvo.ones bolt on with 2 6mm bolts ??
Jaybeee
| posted on 18/10/11 at 12:29 AM |
- have a few but I will need to know what number is on your switch? It starts with 87G or something like that!
I'm back in the country tomorrow and can have a look what I've got
wilkingj
| posted on 18/10/11 at 12:52 PM |
Dont forget to dose the switch with some WD40 or similar.
The top of the hazard switch is open to the elements, and is prone to let water drip down into the switch. It then corrodes and becomes useless.
These switches are getting rarer and are very expensive new. A squirt of WD40 will help lengthen the life of the switch in a Se7en.
Guess how I know this. (It also flattened my battery )
Just my 2d's worth.
Best Regards
Geoff
http://www.v8viento.co.uk
steve8274
| posted on 18/10/11 at 06:55 PM |
samjc. thanks for offer but i intend to stay with ford ones
jaybeee. that would be good if you have one.
the number on mine is 90BG13B302AA
i have tried spraying electrical cleaner and wd40 but still no joy. thanks for advice anyway
cheers
steve
steve8274
| posted on 19/10/11 at 08:33 PM |
any joy?
have you got any switches with same numbers
thanks
steve
