hector
| posted on 11/11/11 at 09:20 PM |
Cossie engine
Would anybody have a spare cosworth engine laying around that they would like to sell?? Any condition will do!!
cheers Colin
needforspeed
| posted on 11/11/11 at 10:32 PM |
205, 200?? standard or modded? have friends with allsorts of specs of engines if you let me know what your after i can ask, no engine specs are cheap
these days tho even high milage standard 205 engines!
DixieTheKid
| posted on 12/11/11 at 08:47 AM |
U2U sent
COS IT'S Worth IT
DixieTheKid
| posted on 12/11/11 at 10:47 AM |
Just to clear up the 200 & 205 block thing. 205 was the early block, has less core plugs, 200 block was later on and stronger than the 205. This
can also be long studded.
205 Block YBD - Sierra RS500
205 Block YBB - Sierra & Sapphire 2WD
200 Block YBJ - Sierra Sapphire/Escort 4WD
200 Block YBT - Escort 4WD
There was also YBG which had a green rocker cover, dont really know a lot about it. There is not a massive amount of difference between them
machincally, the YBD was a bit special, i think you can safely knock that of off your wish list unless you have a lot of wonga!
I think ive got that little lot right.
COS IT'S Worth IT
l0rd
| posted on 12/11/11 at 12:44 PM |
isn't the 205 stronger?
I think that everybody says it is.
I might be wrong though
hector
| posted on 12/11/11 at 04:17 PM |
Ideally I would like a complete engine as i have just acquired a Mk1 escort rolling shelll which i plan to put it in!, I dont mind the rebuilding of
it, also need a T5 box if poss!!
cheers
spiderman
| posted on 12/11/11 at 04:44 PM |
Hi,
I have a complete set up in a 4x4 Sierra Saphire, let me know what you want.
Spider
DixieTheKid
| posted on 14/11/11 at 11:22 AM |
quote: Originally posted by spiderman
Hi,
Do you have the engine harness and ecu (is it l8)?
COS IT'S Worth IT
spiderman
| posted on 14/11/11 at 12:57 PM |
Hi Dixie,
Yes I have got the set up still installed in the car so loom and ecu are there and I beleive all 4x4 Sapphire ecus are L8, though I stand to be
corrected as I have not had eyes on to check it.
I have offered the whole package to "Hector" Motor/turbo/intercooler/silicon pipes/manifolds(inlet/exhaust)
/ecu/loom/injectors for £1750 .If he does not want the whole package I may split it and sell in parts for a better price. But I will give him the
chance of first refusal.
Spider
DixieTheKid
| posted on 14/11/11 at 01:04 PM |
Hi Dixie,
Fair shout, 1st refusal to Hector. Keep me posted. I might have the lot.
[Edited on 14/11/11 by DixieTheKid]
COS IT'S Worth IT
spiderman
| posted on 14/11/11 at 01:12 PM |
Hi Dixie,
Will do.
Spider
hector
| posted on 14/11/11 at 04:46 PM |
spiderman, PM sent
JAMSTER
| posted on 15/11/11 at 01:20 PM |
found this any help
http://www.turbosport.co.uk/showthread.php?173138-2wd-cossy-engine-and-t5-gearbox
