Author: Subject: Mx5 mk1 rear hub wanted
sdh2903
posted on 23/6/15 at 07:08 PM Reply With Quote
As above need a rear hub for a mk1 mx5 please as it sustained damage during separation from driveshaft!!
Only need the hub but would take an upright if you can't be arsed removing the hub.
steve
clairetoo
posted on 23/6/15 at 07:59 PM Reply With Quote
I've got one here with a dead bearing and a rusted-in lower bolt.........any use ?
Postage might kill it , but its free.............
Its cuz I is blond , innit
Claire xx
Will weld for food......
sdh2903
posted on 23/6/15 at 08:19 PM Reply With Quote
Hi Claire. As long as the hub itself is ok that would be spot on. I've got a full new set of bearings ready to fit anyway.
If you let me know how much to post would paypal be ok?
clairetoo
posted on 23/6/15 at 09:43 PM Reply With Quote
Just back in from the shed.........
I'll check tomorrow , and let you know
Claire xx
sdh2903
posted on 23/6/15 at 09:47 PM Reply With Quote
Ta very much!
posted on 24/6/15 at 11:56 AM Reply With Quote
What happened to the hub during removing the shaft?
Just asking as I am struggling to get the shaft out of mine!
sdh2903
posted on 24/6/15 at 01:06 PM Reply With Quote
I happened to it!! Lost my rag trying to get the shaft out and took a chunk of it off.
I eventually got the shaft out after 3 days soaking in penetrating oil. Then in my 12 ton press at max pressure then a smack on the hub and it finally popped out.
posted on 24/6/15 at 02:18 PM Reply With Quote
Ok, mine been in the vice for about 5 weeks soaking in penetrating oil!!!
sdh2903
posted on 24/6/15 at 02:30 PM Reply With Quote
You've obviously got way more patience than me
sdh2903
posted on 29/6/15 at 06:03 PM Reply With Quote
Any joy Claire?
