number-1
posted on 15/8/23 at 05:16 PM |
WTD 6 or 10 tonne hyraulic press
Has anyone got a 6 tonne hydraulic press they no longer need? I need to push out some ball joints from some really really rusty VX220 wishbones that i
plan to refurb. The generic G clamp device i have wont budge them
Ive seen a few on ebay but thought id ask on here first
Ideally the closer to Aylesbury the better but have wheels, can travel
gremlin1234
posted on 15/8/23 at 07:24 PM |
could you just take a piston assembly from a trolly jack?
number-1
posted on 16/8/23 at 05:04 PM |
I tried to bodge one using a bottle jack but no luck
I found a new 6 tonne press for £70 delivered from Here
Also...is it Tonne or Ton??
Sanzomat
posted on 16/8/23 at 07:18 PM |
Both - depending on if its metric or imperial. Tonnes are metric i.e. 1000kg. Tons are imperial. A UK ton is 20 CWT. a CWT (or a hundredweight) is
112lbs or 8 stone. A UK ton is therefore 160 stone or 2240lbs or 1016kg so there is only 16kg difference between a tonne and a ton. Of course its
different again across the pond so better sticking to the metric versions as they weigh the same everywhere.
