Author: Subject: MX5 hubs uprights whatever they're called.
Big T
posted on 13/9/23 at 10:22 AM Reply With Quote
Hello Locost Builders.
I am going through a phase with my locost at the moment. As such I am after the following.
A full set of front and rear MX5 uprights, hub assembly's, whatever they're called! From what I understand the mk1 and mk2 MX5 are the same. So either will do.
I am after the cheapest possible option. If you're in the South Eastern pocket of the world i am able to collect. I travel to Lincoln and North devon quite frequently as well so could collect enroute.
Please if you have anything drop me a message.
I will also be after a Rear diff and shafts at some point so if you have those, that would be helpful.
Thanks!
