chrisg
posted on 6/2/05 at 09:44 PM |
Stainless rod
Hello
Does anyone konw of a scource for 3mm stainless steel rod?
I need two pieces about 300mm long.
Or one piece 600mm, I have a hacksaw
Any help would be apreciated.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Mark Allanson
posted on 6/2/05 at 09:52 PM |
1/8" welding rod? Executive coat hanger? Mrs G's oven shelf?
Mix
posted on 7/2/05 at 10:06 AM |
Silver steel may fit your bill. It's not stainless but is accuratley ground to diameter and thus has a very good finish which could be protected
with laquer, it also comes in 330mm lengths and is obtainable from good tool suppliers or the likes of RS Components or Axminster power tool
centre.
A word of warning, this is carbon tool steel and as such can be tempered to suit it's application, rapid quencing after welding will make it
brittle.
Mick
Coose
posted on 7/2/05 at 01:53 PM |
Try B&Q of all places! They sell all sorts of short lengths of bar stock, tube, flat bar/angle and extrusions!
Spin 'er off Well...
bob
posted on 7/2/05 at 02:58 PM |
chris
Have you tried model shop,and i dont mean ...........well you know what i mean.
Avoneer
posted on 7/2/05 at 05:57 PM |
I could do with a 12" piece 5/8 thick.
Pat...
chrisg
posted on 7/2/05 at 07:06 PM |
Pat...
we're still talking about steel here aren't we pat?
12inch is fine, 5/8ths is a bit thin!!!!
Thanks for the replys chaps- it has to be stainless - its for my side screen hinges.
cheers
Chris
[Edited on 7/2/05 by chrisg]
Mk-Ninja
posted on 7/2/05 at 07:20 PM |
Try your local RS Components they stock it.
I'm sure I've got one, just don't know where I've put it
907
posted on 7/2/05 at 09:35 PM |
A couple of welding rods any good?
Knock the flux off and polish up with a bit of wet & dry.
U2U me if you want them.
Paul G
[Edited on 8/2/05 by 907]
welderman
posted on 7/2/05 at 11:05 PM |
Ye use welding rods, 3.2 mm should do the job. 316 st/st top quality.
