Simon F27
| posted on 18/9/05 at 09:03 AM |
Rear Fill Rocker Cover
I need to know where I can get hold of a modified pinto rocker cover with rear oil fil, or if there is some place that will modify for you.
marshall
| posted on 18/9/05 at 11:14 AM |
hi i need mine done to i was going to ask tiger how much it was going to cost hope some one helps
Jon Ison
| posted on 18/9/05 at 11:26 AM |
Its a pretty easy job too do yourself if you have a welder or know someone who as..........
just remember too put some sort of baffle plate behind it too stop oil splashing around and finding its way out thru the mesh gauze in your filler
cap........
Failing that do the prop work and get a local fab shop too weld it up for you, they will do it for the cost of a pint if you do the prep work.
bob
| posted on 20/9/05 at 11:08 AM |
Could be a bargain,just found it by chance.
http://cgi.ebay.co.uk/PINTO-CAMCOVER-with-extra-breathers_W0QQitemZ8000400081QQcategoryZ72205QQrdZ1QQcmdZViewItem
mad-butcher
| posted on 20/9/05 at 07:07 PM |
why?
