omega0684
posted on 28/5/06 at 09:31 PM |
type 9 gearbox bolts,
as the title says fellas, i need a full set, can anybody help me out?
ATB omega
omega 24 v6
posted on 28/5/06 at 09:49 PM |
Which ones?
cover plate
bellhousing to box
or bellhousing to engine.
omega0684
posted on 28/5/06 at 10:13 PM |
bell housing to engine block please
DIY Si
posted on 28/5/06 at 10:16 PM |
Just go get some from the local bolt place you lazy sod. Should be something like m12x35-40mm long knowing ford.
omega0684
posted on 28/5/06 at 10:19 PM |
can anyone confirm si's bolt suggestion, what size are the gearbox bolts?
DIY Si
posted on 28/5/06 at 10:28 PM |
Oh, and they should be at least 8.8 grade. I wouldn't use anything less regardless of what it's holding together.
britishtrident
posted on 29/5/06 at 07:38 AM |
Thread depends on which engine it is being bolted to ---- Ford UK Kent (pre-xflo, xflo, Twincam, BDA, BDG ) engines and Esssex engines (V4 & V6)
engines were all UNC while the the Pinto, CVH, Zetec, Colonge V4 & V6 are metric.
flak monkey
posted on 29/5/06 at 07:45 AM |
Pinto ones are M10 IIRC from cleaning the threads out on my block.
Sera
http://www.motosera.com
posted on 29/5/06 at 07:50 AM |
From memory the bolts that screw into the gearbox are 10x1.5mm (the bolts on the side of the engine) the top bolts depend on the engine being used as
already pointed out . Pinto bolts are the same thread but be careful NOT to use bolts that are too long . X flow I believe are UNC.
Krismc
posted on 29/5/06 at 08:27 AM |
i can confirm they are metric ones some are 45mm (8 i think) and the other 2 are 40mm (these 2 point towards the engine!
only £2 from ford for the set
Danozeman
posted on 29/5/06 at 10:19 AM |
M10's. Some are 30 and some 40 long. Just get longer ones and cut them to the right length.
Dan
