Author: Subject: English diff - 3.54 or less?
paublo999
posted on 28/9/06 at 07:17 PM Reply With Quote
Anyone with a 3.54 English diff available for sale?
Ideally LSD
Ideally recently serviced, quiet etc...
Ideally a custom ratio lower than 3.54 - 3.1/3.2 etc.
Any combo of the above considered.
Paul
Fatgadget
posted on 28/9/06 at 11:43 PM Reply With Quote
An English diff higher than 3.54?
My guess is one of these is going to be big coin. ...Try Gartrac or Fostek.
Kissy
posted on 29/9/06 at 05:40 AM Reply With Quote
Don't tell us you've got a CBR1000F...
That or a V8?
paublo999
posted on 29/9/06 at 10:15 AM Reply With Quote
yes... a Fireblade 918 that screams it's n*ts of at 70mph... but it is fun getting to 70...
A local (Central belt of Scotland) motorsport dealer is looking for customer crownweel and pinions for me, he suggested that race engines rev to 10k so a low 3.x should be available... but finding one is another matter...
I have sourced a standard rs1600 3.54 diff from another forum, which will give me a cruising speed of 70 at around 6900/7000rpm... but would prefer a custom ration and an LSD
Anyone hens teath or pigs with wings around?
Paul.
procomp
posted on 29/9/06 at 01:37 PM Reply With Quote
Hi all custom ratios for the english diff went the other way Ie high 4's low 5's for the rally lads. To my knowledge no one makes a custom low 3 ish diff for the english axle and to have one properly made as a one off would not be anything like economical there was people on about getting together to do a bulk order but nothing ever came of it.
cheers matt
(edit to say) Your only other option would be to fit the baby atlas axle with the capri diff in which is available with low 3 ratio. But the weight of the axle would mean that in a BEC the car would never handell correctly and you would never get the rear dampers/spring combo to work on a car of that weight.
[Edited on 29/9/06 by procomp]
Coose
posted on 29/9/06 at 01:42 PM Reply With Quote
To be honest, if you want a higher ratio diff for an English axle it may be worth reviewing your rear suspension setup entirely and going for a Freelander diff? There's not a chance in hell of getting anything higher than a 3.54 as procomp says, so you can either change the back end or fit bigger wheels (but who would want more than 13" anyway? )!
I'm quite happy with my R1/3.54/13" wheel setup - it does 80 (on private roads of course) at just over 7500 rpm and tops out just below 125mph - what more do you need?
Spin 'er off Well...
StevieB
posted on 29/9/06 at 01:52 PM Reply With Quote
The only problem with using 13" wheels is if you have a sierra disc rear brake system - 13" wheels won't fit ( ).
Coose
posted on 29/9/06 at 02:11 PM Reply With Quote
I think someone said that Compomotive CXRs will. And as it happens.....
StevieB
posted on 29/9/06 at 02:17 PM Reply With Quote
I better start saving my pennies for some then!
paublo999
posted on 30/9/06 at 04:53 PM Reply With Quote
Thanks guys, got the old diff out today and now need to find out all about
the "crush washer" as the flange will need changed on the replacement diff... Old westfields like mine use a 3'' and I believe the replacement is bigger..
Boy is this kitcar stuff good fun...
Still stupid, but learning fast...
[Edited on 30/9/06 by paublo999]
