itguy
| posted on 17/1/07 at 08:53 PM |
Valve Spring Compressor - to borrow
Hi Everyone
Has anyone in Leicestershire got a 16v Valve Spring Compressor that I could borrow for a few weeks while I do my zetec rebuild?
I've got an OHV one but it doesnt fit (obviously) and as its something I'm going to use so infrequently I'm after a borrow if
poss...
Will.
oliwb
| posted on 17/1/07 at 10:26 PM |
You can use a pillar drill (in fact its even easier to use a pillar drill and bit of pipe) - obviously if you have one! Oli.
mike smith1
| posted on 18/1/07 at 11:10 AM |
If you are struggling pop down to your local engine rebuilders, he may have a yoke that will fit your existing valve spring compressor that will
enable you to get into the recess. (for a small amount of beer tokens)
If you are struggling i will have a look when i get home if i have a yoke lying around that mite do the job not 100% though
HTH
Mike
NS Dev
| posted on 18/1/07 at 11:13 AM |
yep, got one you can borrow, I'm just up the road from Mallory Park, other side of leicester from you but not too far
