Author: Subject: WANTED - 2wd Long nose type 9 from 2.8 ford
Hammerhead
posted on 3/5/07 at 10:56 AM Reply With Quote
I desperately need a type 9 gearbox with a longer nose, (long input shaft) from a V6 sierra. Anyone got one for sale or to swap for a clean standard type 9?
Cheers.
Steve.
mike smith1
posted on 3/5/07 at 11:14 AM Reply With Quote
Steve,
Could possibly help have a 2.8 V6 XR4X4 Donor car.
Is it the same box as you have said 2WD?
Mike
[Edited on 3/5/07 by mike smith1]
Hammerhead
posted on 3/5/07 at 11:33 AM Reply With Quote
thanks, but it needs to be the 2wd version.
mike smith1
posted on 3/5/07 at 11:43 AM Reply With Quote
I didnt know they did a 2WD V6 Sierra, you learn something new every day!
Mike
Mr G
posted on 3/5/07 at 12:11 PM Reply With Quote
Mike
It's called an XR4i - Not to be confused with the 2.0l version they gave the same badge in the 90's
If Mike Smith's box is a type 9 v6 then you can remove the rear transfer box and replace it with a normal 2.0 tail housing very simply. Although the selector rod needs re-drilling as the pin is in a different location that retains the gear level spring.
There is also no speedo drive as the 4x4 boxes don't have the speedo cog on the output shaft (it's on drive output that passes through the sump)
G
[Edited on 3/5/07 by Mr G]
