RichardK
| posted on 18/7/07 at 07:12 PM |
Pinto Inlet manifold take off elbow
I have two of the coolent pipes sealed off but I'm short of one, you can see the hole that needs sealing, has anyone got a spare elbow I can
have to weld up, welded up the one on the right which seems ok, haven't got access to a tig set so can't just weld a plate over.
See picture below:
TIA
Regards
Rich
Gallery updated 11/01/2011
mitch2b
| posted on 18/7/07 at 07:33 PM |
can you not use a blank end from the plumbers merchant?.
its a std pipe thread so a blank/stop should be available,
Mitch
RichardK
| posted on 18/7/07 at 08:03 PM |
Not thought of that, what do I ask for? so I don't look like too much of a prat
Ta
Rich
mitch2b
| posted on 18/7/07 at 08:10 PM |
sorry, your going o have to look a pratt
or go B&Q and see what they have.
buy a few that look about right and take others back
Mitch
James
| posted on 18/7/07 at 08:14 PM |
IIRC I've fed my crankcase ventilation into that hole. Seems to work ok!
- Muhammad Ali
MkIndy7
| posted on 18/7/07 at 08:16 PM |
Either measure its rough size i.e 1/2" BSP..
Or take the (brake servo?) fitting off thats to its right in the picture as it looks the same size?.. and take that to the merchants and ask them for
a plug to match.
Fatboy Dave
| posted on 19/7/07 at 05:56 PM |
I used the plug from a 1/2" stop end from B&Q on mine
Dave
Stop the planet, I want to get off
dickieboy
| posted on 20/7/07 at 09:29 AM |
elbow
I may have one, i have got a spare manifold but not sure whats on it, will look tonight and let you know!
I thought that port was for the crankcase breather aswell?
RichardK
| posted on 21/7/07 at 08:56 AM |
Rover sump plug is perfect!
Rich
