jamestziros
| posted on 16/8/07 at 12:56 PM |
Sierra Discs
Hi
Does anyone have some good condition discs for MK rear end.
Sierra Discs.
SyKaTurbo
| posted on 16/8/07 at 01:00 PM |
What size are they
253mm or 273mm? You looking for standard or performance drilled and grooved ones?
mackei23b
| posted on 16/8/07 at 02:14 PM |
Hi there
I've got some unused spare discs, 253mm. Some light surface rust from storage, but can easily be cleaned off. I can post a pic.
Yours for £20 + postage at cost. If interested send me a U2U
Ian
[Edited on 16/8/07 by mackei23b]
jamestziros
| posted on 16/8/07 at 02:56 PM |
Arr
I am not sure what diameter - did not know there was a difference. Actually this will explain why one of my bearing housing has a shorter mounting for
the brake calipers.
I am assuming I was going to use larger dia.
Is there something I am missing. I as using 15" rims so I dont think fitting in the larger ones would be an issue.
James
britishtrident
| posted on 16/8/07 at 03:09 PM |
Sierra solid rear discs come in 2 main sorts normal or cosworth.
The normal Sierra rear disc is 253mm dia and costs about 6 quid +vat + p&p from BuyPartsBy.
Your local motorfactor may beat this price.
The Cosworth solid rear disc is 273mm dia and is priced at 12.68+vat + p&p.
Even with 253mm dia discs you may find the car is way over braked on the rear ---- brakes that are too big aren't a good idea as you may have
trouble getting the pads up to temperature.
