TimC
| posted on 8/10/07 at 08:51 PM |
WTD: Sierra Driveshaft Washers
Evenin' all
I've lost the large washers used when bolting the driveshaft flange to the hub. Does anyone have any spare for a few beer tokens.
Macbeast
| posted on 8/10/07 at 09:24 PM |
You mean the washers that go under the hub nuts ?
I'll have a look.
TimC
| posted on 9/10/07 at 08:06 AM |
Hi Macbeast
Yes - that's the ones!
Macbeast
| posted on 9/10/07 at 10:01 AM |
OK, I have new bearing sets for front hubs. I know they include hubnuts but not sure about the washers. If there are new washers the old ones are
yours, but it'll be tomorrow before I can get them.
Will let you know asp.
SyKaTurbo
| posted on 9/10/07 at 10:47 AM |
Front washers are different to the rear ones for push in shafts on mine.
mcerd1
| posted on 9/10/07 at 11:18 AM |
front or rear ?
if rear, push-in or bolt-on ? (don't know if they are different)
I should have some spare rear ones from a granada with bolt-on shafts
on my front ones they are splined onto the stub axle (the outside is toothed for the ABS sensor) but the rear ones (bolt on shafts) are just big
washers
TimC
| posted on 9/10/07 at 12:54 PM |
Rear for bolt-on type (lobro) shafts please.......
[Edited on 9/10/07 by TimC]
mcerd1
| posted on 10/10/07 at 09:24 AM |
I'll have a look later and get back to you....
Macbeast
| posted on 10/10/07 at 05:04 PM |
Sorry M8, had a look and the bearing kits do not include new washers so I'll be needing my old ones myself.
Hope someone else can help.
mcerd1
| posted on 14/10/07 at 10:13 AM |
Still need a pair of washers ??
I've got 1 spare set (sorry pics a bit big)
mcerd1
| posted on 17/10/07 at 12:38 PM |
if anyone wants to know they mesure:
45mm outside diam.
5mm thick
~22.2mm hole
