triumphdave
posted on 18/11/07 at 05:05 PM |
quite a lot really
O.K I am after a few bits for my c20xe install,
Pick up pipe steady bracket (any cond urgent)
swirl pot
high pressure fuel pump to supply approx 200bhp
Gsxr 1000 TB's (respaceable k1-k3)
filters,fuel pipe
crankshaft pulley bolt socket(torx type)
electrical connectors for water oil senders (secondhand o.k if some wire is attached)
rubber hose that connects the back of the waterpump to the plastic water rail(has another outlet I think goes to the manifold or maybe the rad?)
sure there is a few other bits I have forgot I can add later.
liam.mccaffrey
posted on 18/11/07 at 05:10 PM |
cant help with your requested stuff bu I have 2 manta 1.8 gearboxes if you your interested
Build Blog
Build Photo Album
triumphdave
posted on 18/11/07 at 05:19 PM |
Thanks but i have just bought a bellhousing for my type 9
jollygreengiant
posted on 18/11/07 at 05:37 PM |
If my memory serves me right, the front pulley bolt (according to Vauxhall) is a use once ONLY bolt. So just use a normal 6 point socket (yes
contrary to common belief they do fit but I can't remember what size it is, ie metric or imperial). old bolt out new bolt in. JD.
MkIndy7
posted on 18/11/07 at 06:27 PM |
The correct socket for the bolt head is an E20, And its BLOODY TIGHT!.
When I changed the timing belt on my car I was told by the Vx dealer that they were no longer avilable! but I did manage to get a Thread size out of
them but either no length or pitch to replace it with something like a nigh tensile allen bolt as I couldn't think of anything else to use.
The fuel pump that came on the Xe engined car is pretty capable and is an external free standing one.
I'm pretty sure normal crimp connectors can be used on the water temp senders, an uninsulated female blade crimp 90 deg on to normal does for
the 1 thats like a T shape at 90 deg to the block.
chriscook
posted on 20/11/07 at 09:45 PM |
Have just rescued the bit of rubber hose out of the bin I might have a spare a oil pickup pipe bracket too.
I'll stick them in the post if you u2u me your details - just send a few quid to children in need in lieu of postage.
Chris
triumphdave
posted on 21/11/07 at 07:47 AM |
Chris
That brilliant thanks a lot chris you have u2u
