Author: Subject: Crossflow water pump pulley
Mr G
posted on 21/5/08 at 06:38 PM Reply With Quote
Come to assemble the xflow and sod's law the water pump pulley seems to of vanished.....
So if anyone has one. 1300 engine, end of pump is 4 bolt with reverse thread for viscouse fan incase it makes any difference
G
BillHoll
posted on 21/5/08 at 06:50 PM Reply With Quote
I think I may have one as I changed to astandard pump. I will search the garage and let you know tommorrow. you can have it for free the only cost will be the postage.
Bill
skodaman
posted on 22/5/08 at 02:45 AM Reply With Quote
Think i've got a spare one as well. If BillHoll can't find one u2u me. Again free apart from postage.
Skodaman
Rek
posted on 22/5/08 at 07:09 AM Reply With Quote
Dont know which it is but i have a spare pulley with the smaller offset you are welcome to. let me know via u2u if you want it.
Mr G
posted on 22/5/08 at 11:37 AM Reply With Quote
Thanks for all the offers lads
Will keep you updated on my quest for the holy pulley
David Jenkins
posted on 22/5/08 at 11:50 AM Reply With Quote
You might like to consider fitting a turned steel pulley - Burtons recommend changing the stock pressed steel one as they have been known to burst at high revs. In fact, it's their No.1 recommendation!
But the stock one will probably be fine, unless you are planning to rev the nuts off it all the time. Oh, hang on, this IS a Locost!
simes43
posted on 27/5/08 at 04:30 PM Reply With Quote
The standard item will let go.
The Burton route does make sense.
posted on 27/5/08 at 06:34 PM Reply With Quote
Isn't that the crankshaft pulley rather than the water pump pulley?
David Jenkins
posted on 27/5/08 at 07:15 PM Reply With Quote
Oh yes... <blush>
