Author: Subject: 32mm connector with 8mm T wanted
Jasper
posted on 15/9/08 at 10:27 AM Reply With Quote
I need a 32mm coolant pipe connector with an 8mm T off it to run back to the header tank. Any ideas where I might get one? Tried Raldes they don't stock it.
I can get one made up easy enough, but wonder if I might get on off the shelf.
tegwin
posted on 15/9/08 at 10:40 AM Reply With Quote
Go to Focus DIY...get a range of their solder ring pipe connectors and make up the connector you need.....Worked fine for me...and was not as expensive as having an ali one made up from scratch!
www.verticalhorizonsmedia.tv
welderman
posted on 15/9/08 at 02:40 PM Reply With Quote
will check stock on 8mm tube for you, if so i can help
Joe
Thank's, Joe
I don't stalk people
posted on 15/9/08 at 02:57 PM Reply With Quote
28mm is the biggest normal copper water pipe. You should be able to get a 28mm-8mm-28mm tee then you'ld just need some 28/32mm reducing hoses at either end.... Otherwise you can get the 8mm screw-in hose connectors....
Jasper
posted on 15/9/08 at 03:07 PM Reply With Quote
All too messy I think, no space for reducers etc..... better just get one made up I think......
welderman
posted on 15/9/08 at 03:57 PM Reply With Quote
i can offer you 32mm o/d c/w 8mm T in stainless, if thats any good to you?.
Thank's, Joe
