Author: Subject: *WANTED* Pinto Fuel pump drive mechanism.
James
posted on 5/1/04 at 04:42 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=9668
Anybody whose broken a non EFI Pinto got a spare drive 'pin/rod' and mechanism to drive the mechanical fuel pump from the cam on the timing shaft to the pump?
I'm converting my EFI 2.0 to run off carbs and want to use a mechanical pump. I've got the pump but not the drive pin for it!
I'm not sure if it needs to be a 2.0 tho.
Thanks,
James
Mk-Ninja
posted on 5/1/04 at 08:14 PM Reply With Quote
See reply in E&T
I'm sure I've got one, just don't know where I've put it
James
posted on 6/1/04 at 03:06 PM Reply With Quote
I've u2u'd you!
James
Mk-Ninja
posted on 6/1/04 at 03:33 PM Reply With Quote
You have reply
