dunk3
| posted on 16/9/08 at 04:06 PM |
brakes
hi all i will be having discs front and rear on my mk indy zetec .will i need a brake bias adjuster fitted (i think thats what they call them ) or
will a normal master cylinder be ok. cheers..
Hellfire
| posted on 16/9/08 at 04:08 PM |
You'll probably need one... front/rear balancing is well needed....
Paul TigerB6
| posted on 16/9/08 at 04:40 PM |
What pedals are you going to use - a single or twin master cylinder design??
dunk3
| posted on 16/9/08 at 04:52 PM |
brakes
will be using mk floor mounted pedals with singal master cylinder
Paul TigerB6
| posted on 16/9/08 at 05:22 PM |
As Steve says then in that case, you will likely need one to reduce the braking effort to the rear disks as these are likely to be too efficient. I
had a Willwood one in my first car and had to restrict the rear brakes fairly considerably.
dunk3
| posted on 16/9/08 at 05:51 PM |
ok thanks
