dunk3
| posted on 22/10/08 at 05:40 PM |
clutch release arm
hi all do i need any other modifications when i mate my 2.0 zetec to my type 9 gearbox . such as the clutch release arm. i have already put
the spigot bearing in. and choped the side of the engine for the starter motor to fit . is there any thing else i need to do. cheers.
tomblyth
| posted on 22/10/08 at 06:41 PM |
1.8 FLYWHEEL OR LIGHTEND STEEL FLYWHEEL!
big_wasa
| posted on 22/10/08 at 07:33 PM |
longer thrust bearing than standard
Dusty
| posted on 22/10/08 at 07:53 PM |
1.8 clutches are a bit wimpy and will slip at about 150 bhp. If you use the mondeo clutch use release bearing Quinton Hazel CCT133.
If you get the flywheel drilled for a sierra clutch and organic plate it will take 200 easily and use the standard sierra bearing.
