CRAIGR
| posted on 20/10/10 at 04:07 PM |
OT. Mira electric shower.
My old mira electric shower has finally bitten the dust
Anyone on here able to better the ebay prices for a new mira play 9.5kw shower .
[Edited on 20/10/10 by CRAIGR]
jossey
| posted on 20/10/10 at 04:16 PM |
get a galaxy 10.5 shower.
really good ive bought about 5-6 of them for houses ive done up.
i got mine for £99.99
http://www.alertelectrical.com/prod/1066/galaxy-aqua-3000-instantaneous-electric-shower-85kw-satin-chrome?utm_source=google-base&utm_medium=web&am
p;utm_campaign=google-base-feed
got mine from falcon in leeds.
hope this helps.
they have a 3 year warranty too.
dave j
Agriv8
| posted on 20/10/10 at 04:17 PM |
usually quit good spared for Mira ( ie new heater elements switches ect ect ) might work out cheaper than a full unit.
regards
Agriv8
CRAIGR
| posted on 20/10/10 at 04:28 PM |
Can get the bits to repair it but its 14 years old now bless it.lol
Will check out the galaxy one Jossey .quote: Originally posted by Agriv8
regards
Agriv8
foskid
| posted on 20/10/10 at 05:03 PM |
don't want to be a sourpuss but do check your mains elect for your shower is up to 10.5 .
I had to rewire to bigger rated cable when I upgraded my shower, something I almost overlooked.
CRAIGR
| posted on 20/10/10 at 05:07 PM |
Good point.
Tis a pretty thick cable going to a 30amp rcd i believe. Current shower is an 8.5. Anyone know if thats ok??quote: Originally posted by
foskid
stevebubs
| posted on 20/10/10 at 05:14 PM |
quote: Originally posted by CRAIGR
Good point.
foskid
Armchair opinion....The 8.5 will (I think) be on the edge of what the RCD (and hence probably cabling) will handle...so would not recommend going any
higher
(8500kW/240v = 35A)
CRAIGR
| posted on 20/10/10 at 05:19 PM |
Just checked it and i lied its a 40amp rcd.
daniel mason
| posted on 20/10/10 at 05:25 PM |
is it a 6.0mm2 cable?
if so it wont carry 10.5 kw. you will ned to put in a 10mm2 cable. hope this helps
CRAIGR
| posted on 20/10/10 at 05:28 PM |
Outer casing of cable is at least 10mm Danquote: Originally posted by daniel mason
| posted on 20/10/10 at 07:14 PM |
If you haven't a clue what you are doing don't risk it, you'll probably burn the house down.
HOW DO I KNOW WHAT CABLE SIZE I HAVE?
1mm² CSA T&E has overall dimensions of 7.8mm x 4.25mm
1.5mm² CSA T&E has overall dimensions of 8.2mm x 5mm
2.5mm² CSA T&E has overall dimensions of 10.3mm x 6mm
4mm² CSA T&E has overall dimensions of 11.9mm x 6.25mm
6mm² CSA T&E has overall dimensions of 13.5mm x 7mm
10mm² CSAT&E has overall dimensions of 17.1mm x 10mm
16mm² CSA T&E has overall dimensions of 19.4mm x 10mm
slingshot2000
| posted on 20/10/10 at 09:25 PM |
Outer casing of the PVC insulation has nothing at all to do with the current carrying capability, of the 'cable' !
The important cable dimension is the;
(cross-sectional area of the copper conductor) in mm(squared); csa
of the copper.current carrying conductor !
slingshot2000
| posted on 20/10/10 at 09:35 PM |
Peteff,
I agree with you about the sizes you have quoted, for British Standard sized cable 'outer sheaths@ , the should be good!
BUT, can YOU guarantee the the cable that may be used to supply a 10.5kw shower is adequate, if you dont know who made the cable ? Or where it was
made?
I have seen many samples of unregulated cable being used in very dangerous conditions! Make sure the cable 'YOU' spec for
'your' job , is capable of carrying the current required by you application !
Be careful out there, dont suggest something you wouldnt do in your own home !
mangogrooveworkshop
| posted on 20/10/10 at 09:59 PM |
quote: Originally posted by slingshot2000
Peteff,
made?
I have found a whole kitchen hanging off a 2.5 twin and earth and a shower hanging off a long run of 4mm.......
| posted on 20/10/10 at 10:52 PM |
Peteff,
made?
Did you read the first line of my post? I'm not going to guarantee anything over the internet just pointing out that the " Outer casing of
cable is at least 10mm Dan " is no indication of what it is wired with. Now where's that get off your high horse smiley.
CRAIGR
| posted on 21/10/10 at 06:20 AM |
Now now chaps we've gone slightly off topic and for peace of mind an electrician has been called.
Many thanks for all the advice as always though guys .
