Author: Subject: Wanted:- Ford Diff bolts (4) please?
Steve Hignett
posted on 14/12/10 at 01:17 AM Reply With Quote
Hi All,
As above, does anyone have 4 diff bolts please?
Ford Sierra diff
Can I use standard bolts from local nut/bolt place and loctite? If so what size ate they? I assume 12.9?
snapper
posted on 14/12/10 at 06:49 AM Reply With Quote
What bolts where?
Diff mounting bolts?
Diff cover bolts?
Drive shaft to diff bolts?
I always go to a Ford parts department first (Lookers in Chelmsford) they usually have what I want and are cheap and will sell singles.
I eat to survive
I drink to forget
mcerd1
posted on 14/12/10 at 08:35 AM Reply With Quote
^^ or diff to propshaft - the little M10x1.0 ones (grade 10.9)
I've got a spare set of these if needed (proper ones off a donor car)
the driveshaft ones are just M8x50 cap heads (Grade 12.9) - you cna get them from any bolt supplier
(that way you don't get the torx head ones )
[Edited on 14/12/2010 by mcerd1]
philtvr
posted on 14/12/10 at 08:36 AM Reply With Quote
Got mine from the local ford parts department, that way you know they are correct thread, length and most important strength.
