Author: Subject: Wanted!!! I need to find a bit of hose and i know you guys can help
tomgregory2000
posted on 26/1/11 at 09:54 PM Reply With Quote
I need to find myself a reducing 90 deg elbow that goes from 80mm to 60mm
Just like this one SAMCO 80MM-60MM OIL RESISTANT 90 DEGREE REDUCER ELBOW on eBay (end time 12-Feb-11 10:54:28 GMT)
but i dont need it to be fuel resistant or that expensive
Its to go between my air flow meter and my turbo inlet as im changing where my air filter is going to sit in the engine bay due to the new intercooler and rad positions and need to get the cold air to it
so can anybody point me in the right direction please
Many thanks
Tommy
tomgregory2000
can go 80 to 63 if that is any easier
flibble
posted on 26/1/11 at 10:03 PM Reply With Quote
RED 76mm - 63mm 90 DEGREE REDUCER ELBOW SILICONE HOSE on eBay (end time 23-Feb-11 09:24:38 GMT)
Or this from america?
matt_gsxr
posted on 26/1/11 at 10:13 PM Reply With Quote
http://www.rallydesign.co.uk/product_info.php?cPath=147_1950_1955&products_id=14132
but its only 76mm to 60mm
looks like you have a difficult one there.
What about this one
SAMCO XTREME 80MM-60MM 90 DEGREE REDUCER HOSE on eBay (end time 12-Feb-11 13:59:27 GMT)
£32 though
[Edited on 26/1/11 by matt_gsxr]
tomgregory2000
posted on 26/1/11 at 10:20 PM Reply With Quote
ive seen the 76mm ones,i just dont think it will strech enough :-( which is a right pain and i dont want to force it over the air flow meter as its a bit fragile and about £200 second hand to replace
matt_gsxr
posted on 26/1/11 at 11:25 PM Reply With Quote
did you see my edited post, the 80mm - 60mm one
still £32 quid though.
tomgregory2000
posted on 27/1/11 at 09:31 AM Reply With Quote
Yes thanks
I dont know how i missed it
Tommy
bigbravedave
posted on 27/1/11 at 12:46 PM Reply With Quote
I have had exactly the same issue with an 80mm maff fitting and a 3" hose. (at 2 in the morning before race day )
we spent a slipery hour trying allsorts to fit it, as the silicon would strech but the fibre reinforcement wouldnt let it go over the bead on the maff.
I ended up putting the maff in the lathe, turning the jaws round on a 3 jaw to pick up on the inside edge, then turning the bead flat to the body diameter then taking a mm off the body material to leave a bead, the plasic in my case was ample thick to begin with and machines to a near mirror finish.
just a thought!
