Author: Subject: wtd: 6mm thick 25mm wide rubber strip
blakep82
posted on 9/2/11 at 04:24 PM Reply With Quote
the sort of thing they use to seal ships hatches in rough seas
its for the fuel tank brackets, somone gave me some sort of neoprene rubber (i think) foam, but it would collect water and rust the steel brackets in time, so instead of foam, i'm after solid stuff.
who has some?
________________________
DarrenW
posted on 9/2/11 at 04:29 PM Reply With Quote
If no-one has rubber maybe consider conveyor belting. might be someone who works in a factory where there may be an offcut that you could cut into strips.
blakep82
posted on 9/2/11 at 04:31 PM Reply With Quote
ooh very good how thick is industrial conveyor belt? it really need sto be at least 6mm thick
MakeEverything
posted on 9/2/11 at 04:51 PM Reply With Quote
Try Pentonville Rubber Products. Its not what you might first think, but it is a rubber supplier near kings cross.
Kindest Regards,
Richard.
posted on 9/2/11 at 04:53 PM Reply With Quote
I'm after some as well to go between the body and chassis on my Jago
40inches
posted on 9/2/11 at 05:11 PM Reply With Quote
Try SOLID RUBBER STRIP 5MM X 1.4M LONG X 50MM WIDE on eBay (end time 19-Feb-11 17:51:02 GMT) or you could use 2x3mm thick strips
blakep82
posted on 9/2/11 at 05:14 PM Reply With Quote
good fine, but not keen on the £8 post, when the item is only £4 lol. having a search on ebay now though. last time i checked i only came up with foam, coming up with better stuff now though
i've emailed pentonville rubber, see what they say
[Edited on 9/2/11 by blakep82]
