Author: Subject: 17mm balls
posted on 30/3/11 at 09:39 PM Reply With Quote
17mm balls
Can anyone suggest a place where I can get 17mm spherical balls? Ideally in a hard plastic, but could be metal.
I want to make a custom mount for my Garmin satnav, and the swivel ball on the mount is 17mm - what's the betting that they picked this size just to be awkward!
I have found stainless steel balls on ebay, but I'm reluctant to pay nearly £7 + P&P for 4 of them...
liam.mccaffrey
posted on 30/3/11 at 10:02 PM Reply With Quote
I have a pot of all the ball bearings from all the scrap cv joints I've ever had. Just had a look for it but can't find it
Though I did find a pair of 15.8 which I think are from an Mx5 you're more than welcome to them. I'm sure my volvo 850 ones were between 15 and 20 mm.
I bet some one will have a scrap cv joint with the correct ball bearing if I can't find mine.
Build Blog
Build Photo Album
907
posted on 30/3/11 at 11:21 PM Reply With Quote
A job for the lathe David.
Paul G
MikeCapon
posted on 31/3/11 at 06:44 AM Reply With Quote
Most bearing shops sell bearing balls loose. I've never needed them that big though.
These people have them. Simply Bearings
I'm sure there are others. Easily found by googling ""bearing balls"uk".
ETA As I had nothing elso to do whilst drinking my early morning coffee...
On this forum there is a guy making them. 17mm delrin ball drilled + tapped out ready at £3 each or a fiver for two....
[Edited on 31/3/11 by MikeCapon]
posted on 31/3/11 at 07:55 AM Reply With Quote
Mike - I've seen that one previously - check out the dates! Mostly 2006, with a couple of updates in 2010.
Paul - I know I should do it in the lathe - but that means making some tooling, and I can't be bothered! I'd rather buy a plastic ball and drill/tap the end... Lazy? Moi?
Liam - it has to be 17mm exactly (within reasonable tolerance anyway) otherwise the mount won't work.
[Edited on 31/3/11 by David Jenkins]
MikeCapon
posted on 31/3/11 at 08:25 AM Reply With Quote
These people might be helpful. They carry stock and claim to have balls up to 8" diameter
Precision Plastic Balls
posted on 31/3/11 at 09:28 AM Reply With Quote
Immaculate timing! I sent them an email not 10 minutes ago!
It's not clear whether they are retail, wholesale or manufacturing, so I asked whether they can sell me 10 or 20.
We'll see how they reply...
posted on 31/3/11 at 05:01 PM Reply With Quote
Hmm - all they've got is 11/16" balls, which is almost equal to 17.5mm.
They've also got a £30 minimum order...
Shan't be buying from them...
stevegough
posted on 31/3/11 at 08:56 PM Reply With Quote
Bins behind the Vasectomy clinic?
Sorry David - not at all helpful, am I?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
bi22le
posted on 31/3/11 at 09:26 PM Reply With Quote
/\/\ only a matter of time before an innuendo about the word "balls" comes out!!! /\/\
Biz
Please read my ring story:
posted on 31/3/11 at 09:43 PM Reply With Quote
You ought to try googling anything with 'balls' in the search text!
