Author: Subject: pipe bending machine LOAN...
jossey
posted on 1/12/11 at 02:57 PM Reply With Quote
so i need to buy a tube pipe bender for my exhaust for my zzr1100 engine. given the cost of benders i was thinking of buying one and selling it on which is fine but does anyone near LEEDS,LINCOLN,DONCASTER,BRADFORD etc have one to loan me for a few weeks for cashhhhhh....
David Johnson
owelly
posted on 1/12/11 at 03:12 PM Reply With Quote
Surely, you'll need a mandrel machine? Trying to use one of those 'bottle-jack in a frame' benders will result in squished, flattened, dented and kinked chimneys.
http://www.ppcmag.co.uk
jossey
posted on 1/12/11 at 03:44 PM Reply With Quote
wont a hydraulic tube bender work ?
David Johnson
jacko
posted on 1/12/11 at 04:44 PM Reply With Quote
No not very good tube benders are for thick walled tube ie 3mm up
do a serch and you will find
Jacko
tegwin
posted on 1/12/11 at 05:08 PM Reply With Quote
You would be better off either finding online or locally a source for ready made bends..... get the ones you need and cut/weld the pipes together to give you what you need... can be done to give really good results if you take time over it
www.verticalhorizonsmedia.tv
designer
posted on 1/12/11 at 05:23 PM Reply With Quote
Yes I agree, buy the bends and straights.
Make's life it a lot easier.
jossey
posted on 1/12/11 at 05:29 PM Reply With Quote
ok guys thanks for your eggspert advice ill get bends etc.
David Johnson
macc man
posted on 1/12/11 at 05:47 PM Reply With Quote
If you make wire formers of the bends needed you could take the pipe to a local exhaust maker. They will form it for not much cash. I did this and saved loads.
